It’s been setting on the work bench for a while but I finally found time to install the doors, windows, interior details, and lighting.
I built a false back interior wall, sides and ceiling from 1/4" plywood. The flooring is stained boards. I attached photos to the side and rear walls and mounted a few detail parts. The pots and pans are doll house accessories that I painted to look like cast iron. Most of the other parts are miscellaneous Ozark Miniatures detail parts from my scrap box. The candy jars are miniature glass bottles filled with tiny beads I stole from my wife’s sewing room (don’t tell her!)
I mounted a 14.8 volt Li-ion battery pack and added a 12 volt regulator.
I installed two strips of LEDs under the ceiling. Each strip has three LEDs.
Here is the view looking through the front door.
This shot is through the left window.
And this shot is through the right window.
Although the sign on the front says that Stan Cedarleaf runs the place, the truth is he spends most of his time at the back door watching the trains go by.
Until the next project strikes,
Bob
