Forums Modeling O / On30
  • Topic: "The Original" Kittom Lumber Co.
    Back To Topics
    (0 rates)
    • July 22, 2016 7:05 AM EDT
      • Tolland County, Ct.
      • Posts
        1,433
      • Thanks
        14
      • Thanked
        18
      Thanks for the update Tom. Time to sit back enjoy and eat my popcorn.
      RRR#2...........Linville Jct. RR
       Live steam.
    • July 22, 2016 6:44 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Hi Ron,
      Well I have a real "cornball" way you can enjoy that popcorn in a rather appropriate rail roady (sp???) way.
      Enjoy your munchin'
      Doc Tom
    • July 22, 2016 7:57 PM EDT
      • Posts
        1,433
      • Thanks
        14
      • Thanked
        18
      Thanks Tom, Your the best.
       Live steam.
    • July 22, 2016 8:01 PM EDT
      • Posts
        14,675
      • Thanks
        2,639
      • Thanked
        1,538
      I thought I was the best?
    • July 22, 2016 8:12 PM EDT
      • Posts
        1,433
      • Thanks
        14
      • Thanked
        18
                 A close second.
       Live steam.
    • July 23, 2016 10:41 AM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      A small steam powered horse makes its way to the Original Kittom Lumber Company.
      A 14 ton Heisler Locomotive from the Stearns Manufacting company was born at their shops in Erie Pennsylvania in 1896. She headed to Dixie to work in the growing lumber industry at the turn of the 20th century. Much like its sister "A.W.Stevens Lumber #1-s/n1007 the Kittom Heisler first went to Mississippi to work the expansive pine forests of the sunny southland.
      These were the first 14 ton models built. As evidenced on the locomotive above wheel counter weights were NOT part of the early locomotives manufactured. Retro-fit kits of cast weights that could be bolted between the spokes were later made available by Stearns.
      After working several southern logging outfits Kittom Lumber's Heisler made it to the wilds of the Kentucky/Tennessee border in 1910.It was a "fourth hand" purchase with a new paint job that helped to disguise the 19th century technology that was its parentage.
      Management was happy that it would fit in the planned engine house. They were itchin' to put it to use.
      Doc Tom
    • July 23, 2016 8:23 PM EDT
      • Coeur d' Alene,, Idaho
      • Posts
        1,418
      • Thanks
        0
      • Thanked
        30
      Looks nice, but I think it needs a little bit of track to go anywhere.  I'm keeping my eye's on this project.
    • July 23, 2016 9:17 PM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,107
      • Thanks
        125
      • Thanked
        904
      I dunno, with the rear light, it looks like the engine house needs to be a bit bigger, or it needs a window right where the light on the loco is.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • July 23, 2016 9:38 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Hi Chuck.
      Well the boys down south in Birmingham are busy cooking up some Pig Iron  to make a few tracks and turnouts.
      "Casting Pig Iron at Sloss Furnace, Birmingham, Alabama, 1906"
      Doc Tom
    • July 23, 2016 9:45 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Well Dave my local model rail road buddies are always critiquing my zest for tight clearances.
      And on these "minis" clearances can get pretty tight.
      Doc Tom
    • July 23, 2016 9:53 PM EDT
      • Posts
        11,107
      • Thanks
        125
      • Thanked
        904
      A miss is as good as a mile?
      Shannon car Shops
    • July 23, 2016 10:20 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Yes another "train  truism."
      Doc Tom
    • July 24, 2016 3:36 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      A BLUE LAYER CAKE FOR KITTOM LUMBER
      I finished cutting up the blue foam panels for the mini layout. From a 4'X8" sheet I cut 14.5" X 48" panels and "dry stacked" them.
      I cut the panels to leave a 1" slot in the center.
      This is where the scenic divider will be placed. And, of course, it too will be made of blue foam board.
      I laid the top layer on so you can get a sense of proportion.This layer will have a 1" slot down the middle as well to accommodate the scenery divider.
      The top of the layout is 50" from the floor. The whole layout without the cabinet/pedestal weighs about 10 pounds and is easily lifted with one hand. So far NO WOOD used in the construction.
      Hopefully the electric wire foam cutter arrives this week and I can begin to rough in terrain contours. I will also sand down the edges of the panels to give the layout a more finished look.
      With a layout this small I went overboard to give it some height for dramatic scenery below track level.
      The height of the layout ,including the divider, off its removable base, will be 30". It should be easy to get in and out doors.
      Thanks for looking.
      Doc Tom
      This post was edited by Tom Grabenstein at July 24, 2016 3:37 PM EDT
    • July 24, 2016 7:28 PM EDT
      • Posts
        1,433
      • Thanks
        14
      • Thanked
        18
      Yes, I can see it. This is going to be great with the elevations.
       Live steam.
    • July 24, 2016 10:40 PM EDT
      • Chaco, Paraguay
      • Posts
        2,719
      • Thanks
        321
      • Thanked
        308
      are all the layered panels of the same thickness?
      My Chaosplace ->
    • July 25, 2016 8:35 AM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Hi Korm,
      Yes, they are all 1 inch thick. Here in the sunny Southland 1" foam is the only insulation available at the building stores.
      Yes, I built up 15 inch layers of foam board. I wanted lightweight above all and so far no plaster or wood in this layouts construction.
      Doc Tom
    • July 25, 2016 6:45 PM EDT
      • Chaco, Paraguay
      • Posts
        2,719
      • Thanks
        321
      • Thanked
        308
      Thanks.
      and be prepared for more stupid questions. your build is timed just right for me.
      when i have finished the section, i'm working on, in some weeks....  some months...  or so....  - then i plan to make some Mesa type background mountains for a desert section.
      so everything i can learn from you now, i won't have to find out the hard way.
      My Chaosplace ->
    • July 25, 2016 7:44 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Korm Kormsen said:
      Thanks.
      Hi Korm.  Here is a GREAT You Tube Video that shows how easy it is to carve the mesa rocks of the American Southwest out of one inch thick foam insulation panels.
      https://www.youtube.com/watch?v=9Zz__jzDNgY&feature=em-share_video_user
      I will be carving some of the rock facings this way on my layout set in Kentucky/Tennessee.This topography in K/T is not as stark or bold as in the Southwest and is overgrown with foliage. Yet, I will carve in some limestone faces near the waterline of the river and creek on the layout. As you watch the video note again no heavy and messy plaster to fool with.
      Looking forward to seeing more your creations too.
      Doc Tom
    • July 26, 2016 7:56 PM EDT
      • Chaco, Paraguay
      • Posts
        2,719
      • Thanks
        321
      • Thanked
        308
      thanks again. looks interesting, what he does.
      well, don't hold your breath for my creations. i'm getting slower and slower.
      and, on top of that, our firdepartment is so short of volunteers, that they reactivated every walking dead, who still is able to cramble into th truck by his own force. i qualified (barely). so now one third of my free time i'm over there, waiting for things, that we hope will not happen.
      My Chaosplace ->
    • July 26, 2016 8:35 PM EDT
      • Posts
        1,571
      • Thanks
        31
      • Thanked
        197
      Be careful out there. I am proud of you as a "first responder."  Doc Tom
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
