OK, so there are TWO sizes associated with a jpeg…
the first is the “physical” size, measured in pixels… 800 x 600 is the max we allow on the site. Most programs allow you to resize to fewer pixels, and call this the resize operation.
The second on is the “storage” size, measured in bytes. To change this, you can do a couple things. The first is resize to a smaller physical size, and the file size will shrink as you make the picture “smaller”
The other operation is the one you are really asking about, the amount of “compression”, which will appear as resolution or “clarity” or “detail” on the picture. This can be widely varying, and with newer cameras, you can get huge files, and modify the compression (increase the compression) and the picture will still look good, in fact many people cannot tell the difference.
To adjust the compression, you need a more sophisticated graphics program. No idea why very few programs have this, but that’s another story. I use the free program Irfanview, and when you save a jpg file, you will have a “slider” to change the compression, which can reduce the file size. Some programs will even read out the file size in bytes as you play with the “slider” but again most easy to use software does not have this.
Adobe Photoshop will also do this, and Photoshop CS2, Version 9 is now free, the download and the serial number is on the Adobe site.
