After reading the various reviews and comments regarding the Track Cleaner sold by Reindeer Pass I just had to get one and try it out. I had an old Delton gondola so I did a little careful cutting and mounted the unit to the front of the floor. I purchased the unit with the additional wiring for switch and charging jack. I decided to use a 14v, 3000 mAh battery for initial testing.
Since the weather is too cold and I have my layout mothballed for the Winter, I could only run a test on an old, very dirty piece of track in the shop. Bottom line, I’m very impressed so far.
Of course, I had to take the project one step further - I added a speed controller because I didn’t want to have the sander sit in one spot until I got the thing rolling.
I was impressed with Dave Bodnar’s find of the little RF LED variable voltage controller so I purchased a few of them to see if they would work with this track cleaner. Bottom line - it worked and for only $7.00 too. It allowed me to remotely turn on the cleaner and to vary the speed.
One thing I noticed during testing is that the controller got a little warmer than I cared for. So, since I had already installed an old Big Hauler weight, I decided to mount the LED controller to it. After a few minutes of run time the controller stayed relatively cool.
An additional comment: The range is very limited indoors so I hope when I take it outside that will improve.
Below are a couple of photos of my installation.
With this new toy, I plan to eliminate my fancy leaf blower and my sanding pole. Life is getting easier.
Doc Watson
