  • Topic: A inexpensive battery RC setup?
    Back To Topics
    (0 rates)
    • December 20, 2015 2:25 PM EST
      • Posts
        13,555
      • Thanks
        1,328
      • Thanked
        927
      I saw that one too Joe. It doesn't have a current rating so I assume it's quite low. It also has effects which might really confuse or damage a motor load if switched on in error, but for LED control it looks interesting.
      This post was edited by Jon Radder at December 20, 2015 2:25 PM EST
      www.cvsry.com www.cvsry.com
    • December 20, 2015 4:49 PM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Right in the title that last one says 5-24v 12A. Now that thing looks interesting. It looks very small. And after reading Dave's write up on the other for reversing couldn't it be wired into a relay where when you turn it off then turn it on it again it will switch to the other direction?
      Dave whats your thought on that one? Has a wider voltage range where for a small critter you could run 7.4v. and it also has a 12A rating though I have no idea why we would need that.
    • December 20, 2015 4:52 PM EST
      • Posts
        13,555
      • Thanks
        1,328
      • Thanked
        927
      Oops - Missed that.  I still have some concerns about the "effects" but for under $2 you could experiment with a spare motor.
      And speaking of electrical experiments, check this out if you want a laugh: https://www.facebook.com/video.php?v=10156173747740702
      This post was edited by Jon Radder at December 20, 2015 4:56 PM EST
    • December 20, 2015 8:01 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        11,109
      • Thanks
        125
      • Thanked
        904
      Oh, at that point he should take up a less painful hobby. Something like knitting, coloring books, or skateboarding into walls.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • December 20, 2015 9:39 PM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        861
      that was the funniest thing I have seen in a long time... I've seen similar people attempt an R/C installation with very similar results!
    • December 20, 2015 9:50 PM EST
      • Deer Park, Washington
      • Posts
        12,567
      • Thanks
        574
      • Thanked
        363
      I couldn't watch the whole thing, too painful.  I'm not even trusted with a light switch.
    • December 20, 2015 11:39 PM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
       I have to laugh (now) because I had two very electrifying experiences. I added a large addition to my house (750 sq ft) and that required an upgraded panel to give me more breaker slots. Well while wiring the panel I thought I had killed the main (the first clue that it was hot should have been the drop light that was plugged in so I could see in the panel). I was tired, I was in a hurry and I was not at all careful. I drug one of the 8 gauge wires that was wiring my new shop sub panel across one of the primary leads and the neutral bus bar. Needless to say there was a very bright flash, a shower of sparks, and a loud bang. Scared the fecal matter right out of me and my wife who is stone cold deaf heard it (I think she saw it more than heard it) and came running to find me sheet white standing there with the wire in my hand with a blank stare. A few months later we had another fun experience, When the new panel was put in the power company had to cut my primary right at the weatherhead. I share a transformer and they didn't want to pull the fuse and kill both houses. So the new panel was installed and wired up and he crimped the old and new wires back together. Well a couple months later the crimp gave way and one of the primaries pulled loose and touched the neutral and all hell broke loose. Big flash, flickering lights then nothing but darkness and flames as it caught my roof and picnic table on fire and finally burnt all the way through and dropped to the ground.
      Me and power do not get along.
    • December 21, 2015 5:14 AM EST
      • Posts
        393
      • Thanks
        10
      • Thanked
        86
      Devon - I ordered two different units for experimentation - I'll see what they can do when I get them.
      Item #1 -   http://www.ebay.com/itm/361162873382?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT - specs:
      Voltage: 5-24V
      Max Load: 12A (144W)
      Distance: 40 ft.
      Item #2 - http://www.ebay.com/itm/200984307947?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT - specs:
      • Supply voltage: DC 12-24V
      • Size: L45*W13*H3mm
      • Weight: 55g
      • Connecting Mode : Common anode
      • Max power output: 3X4A
      Could be more interesting for our purposes as it has 3 separate channels (for 3 colored LEDs - 4 amps per channel) - my thought is to use one (or two in parallel?) channels for motor power and the 3rd channel for a direction relay -
      Stay tuned!
      dave
    • December 21, 2015 11:35 AM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      I love it when smart people are set to a task
    • December 21, 2015 2:24 PM EST
      • Posts
        12,567
      • Thanks
        574
      • Thanked
        363
      PFM.
    • December 21, 2015 4:25 PM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Yeah if that little guy can be made to have forward and reverse at 7.4v that would great for little critters. It will be great for very small locos at 12v.
    • December 21, 2015 4:34 PM EST
      • Posts
        13,555
      • Thanks
        1,328
      • Thanked
        927
      If you order the $1.76 one be sure to order a battery too - it doesn't come with one. I didn't see the battery spec, but from the pictures I found of the same remote on a different unit it looks like a CR2034 - a very common Quarter size lithium battery. You can get them real cheap in 5 packs on Amazon, or pay over $5 each in a retail store.
      P.S. I'm glad you got a kick out of the video. I'm pretty sure it was fake, but still funny. The same guy has a tutorial on how to make an electric guitar. A 110V lamp cord wired direct to the strings. I didn't hear any sound from the guitar, but the guitarist made some interesting sounds.
      This post was edited by Jon Radder at December 21, 2015 4:37 PM EST
    • December 21, 2015 5:22 PM EST
      • Fort Myers Beach & Annapolis, Florida & Maryland
      • Posts
        2,507
      • Thanks
        98
      • Thanked
        486
      Which video?
      Amazon's Q&A says "The battery is a CR2025".  I ordered a 5-pack for $2.76 and free shipping.
        Pete
    • December 21, 2015 5:46 PM EST
      • Saint Johns, Florida
      • Posts
        4,532
      • Thanks
        495
      • Thanked
        721
      The Amazon ad says it comes with a CR2025 (in the questions and answers). Boy Jon, you are missing a lot!
    • December 21, 2015 6:32 PM EST
      • Posts
        11,109
      • Thanks
        125
      • Thanked
        904
      I have had my share of power issues too. In VoTech I was working on a television. In order to work on it the instructions told me to discharge the CRT. Simple, put a clip lead on the chassis, and a long screwdriver, and then get the end of the screwdriver under the rubber electrode cover on the CRT. Only I couldn't get it under that cover, and as I was pushing I leaned in and my belly contacted the chassis, and my hand slipped off the handle of the screwdriver, onto the shaft of the screwdriver, knocking the clip lead off just a moment before the screwdriver went under the rubber cover........... The next thing I remember is standing on the other side of the room, shivering uncontrollably, with the class gathered around me, screwdriver and clip lead on the floor halfway between me and the workbench with the TV on it. One of my classmates picked up the screwdriver and clip lead, handed them to me and said "Do it again." I politely declined.
      Shannon car Shops
    • December 22, 2015 11:51 AM EST
      • Newton, KS
      • Posts
        2,870
      • Thanks
        5
      • Thanked
        116
      I ordered one of those also.
    • December 22, 2015 12:24 PM EST
      • Posts
        2,507
      • Thanks
        98
      • Thanked
        486
      Hmmm...  Maybe this is the one Dave B is playing with ($14.00).  4 outputs connect to the LED strip.
      And there is this one ($7.99.)  Guess I can wait until I hear what they do.
      I searched Amazon and found another half-a-dozen types at prices from $7 to $55.  Guess it's a booming industry.
        Pete
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
