All,
It’s been awhile since i’ve posted, last I had, it was probably on the topic of the Bear Flatts RR.
I have since moved into a new place and decided that the new layout I was going to build was going to be as maintenance free as possible. With the ideas of a layout built inside and mounted to the bench work, I realize that there is very little maintenance required and there aren’t too many opportunities for derailments. My thoughts were basically to bring a shelf layout, outside. Having a “guy” that i can get unlimited pallets from, I decided that this was going to be my base. With five pallets across, each leveled out with bricks on the corner supports of the pallet. Next I attached aluminum screen across the top to be my water run off control. I laid the track and made sure it was exactly how I wanted it before nailing it into place. The loops as seen, are just landscape stone leveled to keep a practically grade free track plan. I ripped some old 1 x that I had and made some edging for the 3/4 minus fill. Finally I brought in the gravel and laid out some buildings. Here is a start to finish in a nut shell of what was accomplished.
Thank you for looking!
Matt
