RMN Kit build
Seems to be a well designed and straight forward kit. Read some necessary “adjustments” on the other forum along with an indepth discussion. Great support with Andrew (Aster UK):
Rebuilt Merchant Navy
We will be doing a second kit and I will film the build process.
Now into stage 8 boiler works and backhead
Here is the air test of the valve gear:
Air test chassis
Going onto the home straight having completed the tender set up:
Tender Step 18
The one aspect that we thought would help prevent a rebuild of the kit was to put crush washers onto the inner cylinder high pressure banjo fitting:
Inner cylinder upgrade
