I have wandered back to HO scale.
This past weekend the White Bear Lake & Santa Fe RR began purchasing equipment. This short line is set in the modern period as a tourist railroad and a common carrier, so steam and diesels will be operated. The locomotive roster includes a Santa Fe FT A-B set, a Santa Fe freight FT A-B set, a B30-7, and a 2-10-2 steam locomotive.
I am building a modular layout. I will be building 6 inch wide track modules & 12 to 18 inch wide scenery modules. This way I can use the track modules with my On30 trains. Corner modules will be 30" square.
Mainline minimum radius is projected to be 26".
Roger
Chief Engineer, C&R Railroad Group
White Bear Lake & Santa Fe RR [HO]
Coyote Ridge RR [On30]
Post Oak & Otter Lake RR [LS]
Caddo Mills TX
