Bill: Kinko's :-)
Bill: Kinko's :-)
Very nice and helpful , now just need a laser printer
Jon: It does show the gel stuff (at least one possible variant of it). Here's the one I used, purchased at Michael's:
You can see a few more bits of into about this kind of sign starting at this page of my Mik build: [link] (scroll to the bottom of the page).
Cheers!
[edited for typo... too early here!]
That's looking great Jim. I need to use this technique on my blacksmith shop build and you have already cleared a few things up for me. I agree with John, list the product you are using at the very beginning.
Thanks Jim - I didn't watch the video yet. Does it explain what the "gel" is? I want to try this.
Folks: I've started my step-by-step tutorial article on image transfer signs [link to article]. Feedback is helpful (just leave comments here if you please). Is this the right level of detail? Too detailed? Missing something essential so far?
Thanks Dan. Rick: ordered. Those look like a good size. Thanks for the pointer!
Jim,
In my buildings etc. that come apart or move, I use "Deans Micro Plugs" 2NR or2NB, red/black, doesn't matter for lights.
You can find them at hobby stores that have model plane stuff. They look like this https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXCGP1
Work great.
Rick
Jim, very ingenious method for assembly/disassembly. Makes storing and maintenance much easier. Thanks for sharing.
Here's a (rough) video that shows how to disassemble Mackenzie's Mercantile:
Congrats to the winners, and excellent builds by all the participants!
https://www.largescalecentral.com/forums/topic/29241/2019-mik-build-challenge-winners
So who won?
Travis Dague said:
Bill Barnwell said:
Travis, when I did mine I used a piece of 1/2" cvpc pipe secured the top to a counter and attached a large pair of vice grips to the bottom then heated it with a heat gun and as I heated it
began to stretch and taper, when it got about to the size I wanted I sprayed it with a water bottle to stop the reaction. then just cut it to length and section the end with left over pieces. later added evergreen strips and chain, worked great and I saved $10 from not buying one from evilbay, Bill
Bill, when it stretched were you pulling it with the vice grips or does it naturally do this when exposed to high heat?...
Travis, they were pretty big vice grips that I used and I did so because I was afraid that if I tried to do it by hand it wouldn't be straight and by hanging with a weight on the bottom it would stretch more uniformly which it did. So to refresh. I anchored the top to the side of a cabinet (could use a ladder) and let about a 1 foot piece of cvpc hand vertically and attached a pair of vice grips to the bottom of the pipe, then heated the pipe uniformly up and down and around with a heat gun and when the tubing reached a bendable temperature it started to stretch and as it did it became elongated. Went it reached a size that looked right I sprayed it with a water bottle to stop the process. I might mention that went it started to stretch it went pretty fast. So the worse thing that can happen is you'll have to do it over and use another piece of 25 cents worth of pipe. I got lucky and was able to get it first time. After cooling I cut it at the small end at about a 45 degree angle and then took the cut piece and rotated it 180 degrees and reattached with super glue after cutting a short piece at 90 degrees off for the tip, being as the 2 pieces with the cut 45 came from the same place/piece the tubing was of the same diameter and required no fitting, then cut the whole to the length I wanted. Good Luck, Bill
Travis, the rings around the spout are evergreen strips, the eyelets holding the chair are brass screw in ones from hardware store and chain is brass saved from a model ship from back in the 6oths, don't throw anything away you might need, I had taken the time to put rivet detail on the top side of the tube, which you can see the bumps in the left side shop, with archer rivet decals but it really was a waste of time being as you cant see them when the spout is up. Mounted the spout by filing a grove perpendicular to the length and gluing a small piece of hollow styrene across it and securing with a bold and it does pivot. Need any thing else let me know, Bill Oh the handle is a piece of bent paper clip
Bill, could you possibly get some close up pics of the spout?. Thanks ....
Travis, here is a picture I found on pinterest, seems like your spout has good company, it's from the black hills railroad, still in operation I believe
Travis Dague said:
I will try to get some more photos of it from different angles...
Actually I think you will find it is from an aristo craft water tank, and if you want a tapered one, other than buying one I suggest you try the heated cvpc pipe that I sent you directions during the build, works and looks great, but I don't see any problem with the 1 you've got, some times it's just best to leave things alone. If you check old pictures you will find that there were lots of different styles, I've even see a square one. Like I said I like it very classy, Bill
