Rick Marty said:
Yea, Rust-Oleum paints, in my opinion, are pretty crappy for model work especially the 2X stuff. Sure it works great on Patio furniture but puts out way too much paint for model work. Kyrlon is not any better in there 2X spray, again just too much paint coming out of the nozzle for model work. I have been moving toward cheap store brands, because they skimp on the paint pigment and you get a finer/lighter coat of paint.
If it says wait 48 hours before re-coat then wait 48 hours, better yet wait 60 hours depending on temp and humidity.
I have almost given up on Ripoff-Oleums paints. In the past couple of years I have probably returned 20 cans to Home Depot because they quit spraying after a single use and sit on the shelf for a month or two. Yes, I know how to clear the nozzle and pull it off and soak in solvent to unplug it, but why in hell should I have to do that. When I buy a can of paint I mark it with the date so I know how old the paint is. I have some cheap hardware store brands in the cabinet that are 6-7 years old and still work fine.
The exception to my dislike of their paints is the automotive primers. They go on smooth and dry exceptionally fast and can be top coated within 15 minutes even in high humidity conditions and the damn nozzles don't clog up.
Doubt if this helped you much but it let me unload on something that has been p-----g me off for a long while.
I have thrown out several cans of Rustolium, It doesn't matter how much I shake them. I even tried shaking them between passes when spraying, but they still clog up on me, sometimes in the middle of my first use of a can. I prefer Krylon, I very seldom have issues with Krylon. As for a second coat, I usually apply a second coat within an hour of the first coat. If I am masking off an applying a second colour, then I do wait 2 days at a minimum before applying the second coat. Also, I make sure and apply thin coats so they can dry all the way through. A thick coat will not dry as fast, and will react to the next coat of paint if its applied too soon.
As for the cheaper off brands, I have used some that work well, and I have used some that, well, just don't cover, or don't give a nice even coat of paint.
