Forums » Reference
List of newest posts
    • December 11, 2017 10:53 PM EST
    • Greg Elmassian said:
      Thanks Jon, started a page will enhance it shortly, probably an explanation of interfacing and powering the main board.
      https://elmassian.com/index.php?option=com_content&view=article&id=739:c-19-wiring&catid=14&Itemid=1175
      OK - Thanks for letting me know you are publishing it.  Please replace the one you have with Ver. 3 above. The one you have is not correct. V3 fixes errors and adds some detail.
    • December 11, 2017 10:49 PM EST
    • Thanks Jon, started a page will enhance it shortly, probably an explanation of interfacing and powering the main board.
    • December 11, 2017 10:19 PM EST
    • I have updated my Tender Board Connector Pin-Out. I discovered a few dependencies once the board was out of the circuit.  I believe version 3 (above and here) is now correct. I have also added some notes regarding the 5V supply required to use the chuff circuits and LEDs if the tender board is removed.
        Regarding Note 4 - This wire only has +5V if +5V is being supplied on the VDD Input  (Note 1)
    • December 10, 2017 11:22 PM EST
    • Whatever you prefer Tony.
      Re gutting - I had a good install previously using the existing socket, but when upgrading the sound board I decided to upgrade the speaker and what I chose won't fit with the stock electronics so it and the weight has to go.
    • December 10, 2017 9:20 PM EST
    • Thanks Jon.
      I was intending to just put it up as a resource for others who might be interested.
      Me, I never ever gut locos unless I really have to.
      I use my own PnP pcb in the tender to take advantage of the existing wiring.
    • December 10, 2017 4:42 PM EST
    • Tony Walsham said:
      Jon, would you kindly allow me to link this thread on my website "How To's"? Proper credit will be noted.
      Sure Tony.  If you would rather have the original PDF of the pin-out I can email that to you. I can also remove the third column of how I am using the pins as that may not apply to your customers.
    • December 10, 2017 4:10 PM EST
    • Jon, would you kindly allow me to link this thread on my website "How To's"? Proper credit will be noted.
    • December 10, 2017 11:50 AM EST
    • Bob can sticky it if he wants to, but in this forum (Reference) it doesn't make much sense because most threads in this category contain similar type of information. Would't keep anyone from copying and re-posting either.  All except my plug pin-out is available elsewhere already.
    • December 10, 2017 11:22 AM EST
    • Thank you Jon any way of making this a sticky? so it doesn't copied and posted some were else.
      Richard
    • December 10, 2017 9:32 AM EST
    • Gathered from Stan Ames, Bachmann and my own circuit tracing.  All images are Hi Res - Use browser's View Image function for full size.
      Schematic Diagram from Bachmann via Stan Ames...
      From Bachmann - Tender Socket DCC Pin Assignment...
      From Bachmann - Circuit Interconnects...
      And finally, from the C.V.S.Ry Over Engineering Department - Tender Plug wire assignments...
    • March 28, 2017 8:30 PM EDT
    • Great song Rooster, I listened to the whole thing. Lot of meat on that bone.
      And great site, Devon. By different paths, we both discovered it. So let us know what things you unearth there!
    • March 28, 2017 10:52 AM EDT
    • Geez and i loved your post cliff and did not put two and two together about the source. I thought the page looked familiar. Duh.
    • March 27, 2017 8:08 PM EDT
    • Yep, they're a great resource. That's where I found most of those old catalogs.
      http://www.largescalecentral.com/forums/topic/26667/old-equipment-catalogs
    • March 27, 2017 10:27 AM EDT
    • https://www.hathitrust.org/
      So just came across these guys today while searching for online copies of the Car Builders' Cyclopedia of American Practice. These are great references for scratch builders of early era cars. These guys have a very good collection available online. But they have tons more. Stuff on everything railroading from back in the day.
    • January 25, 2017 12:01 AM EST
    • Thanks Fred.
      Ken
    • January 24, 2017 3:44 PM EST
    • Glad you now have the picture you were looking for...
      Fred
    • January 23, 2017 10:17 PM EST
    • That'll work! Already printed at, I believe 24 x 18 inch or thereabouts. Had a friend print it on his large printer, now we have to frame it in a few days.
      I thought the original locomotive was a wide cab but this is actually better.
      Thanks Joe!
      Nice photos! Ken
    • January 23, 2017 8:08 PM EST
    • http://rrpicturearchives.net/showPicture.aspx?id=2290486
      http://rrpicturearchives.net/showPicture.aspx?id=2290481
      http://rrpicturearchives.net/showPicture.aspx?id=2346589
      etc.
    • January 23, 2017 8:01 PM EST
    • it just occurred to me what you are interested in. The Aristo dash9 had that paint job. The real engine should be like the MTH narrow nose. I will get a pic for you from the internet.
      looks like 2100 series c40-8 CN.
