Forums » Reference
List of newest posts
    • December 31, 2018 3:43 PM EST
    • Bob Cope said:
      Interesting design Fred. If my memory is correct, Bruce Chandler did a similar article here http://www.largescalecentral.com/forums/topic/17266/bucket-coaling-station.
        Thanks, Bob...don't know how I missed it, or whether I've forgotten, but I felt that build should be brought out of the archives for a second look.
    • December 30, 2018 8:36 PM EST
    • Thanks Fred, I am aware of CPR's light locos in a couple of provinces. Trains and later Classic Trains magazines have shown them.
      I also appreciate how much manual labor was used. I only saw the sand house to the left and weeds behind the stand, so here coal must be delivered by boxcar to keep it dry and neat.
    • December 30, 2018 8:00 PM EST
    • Yes, Bob; Bruce did build one which was similar in it's method of loading coal. It had more of a protective building around it, with a roof and 3 sides, if I remember correctly. He made a great job of it.
        Fred Mills
    • December 30, 2018 7:12 PM EST
    • Interesting design Fred. If my memory is correct, Bruce Chandler did a similar article here http://www.largescalecentral.com/forums/topic/17266/bucket-coaling-station.
    • December 30, 2018 6:39 PM EST
    • John;
         There was a bit of information with the pictures that didn't get included...
        The method of coaling, shown in the pictures  included a lot of manual labour, often involving maintenance of way workers, or any railroad labour handy at the time.  Labour was relatively inexpensive, even into the middle "50's"
        The box car in the photo, may have been used to bring the coal to the stage, after coal was manually shovelled into it from a coal pile, somewhere in the engine facilities. Its floor was at the correct height to match that of the coaling stage.
       The hand truck, in one of the pictures, being used by the "White suited" worker, was used to load the coaling buckets. Each bucket had a drop bottom.
           You must understand, that in Chipman, New Brunswick, at the time, there was seldom if ever, more than 2 4-4-0 locomotives in service. There were 3 of them that the CPR kept in service, just for the branch line, late into the 50's, due to the need of a very light locomotive, to cross a particular bridge. The locomotives were CPR numbers 136, 144, and 29. All were preserved at one time. 144 was possibly lost in a fire somewhere in Nova Scotia; 29, and 136 still exist...29 is in Ontario...I'm not sure where 136 is...
         There were a number of coaling stages such as this one.  There were at least 3 of them, not far from Ottawa, at one time, up until the end of steam in the very early 50's.
       Fred Mills
    • December 30, 2018 5:54 PM EST
    • Is the coal brought in by boxcar?
      Loved the white uniform.
    • December 30, 2018 4:02 PM EST
    • That actually seems to have worked.  Enjoy.
      Fred commented that the topic of small coaling facilities often arises, and also that engine servicing, which I hasten to add is often under represented, can make a significant contribution to our operations.
      Thanks for this, Fred! (Mills - is there any doubt?)
    • December 30, 2018 3:56 PM EST
    • Fred has asked me to upload these four pics for him.  Wish me luck....
    • September 8, 2018 5:05 PM EDT
    • OOps, all that and I uploaded the sort of almost but not quite done version.
      Here is the proper version
    • September 8, 2018 4:58 PM EDT
    • So I spent the afternoon with MS paint, and when it came time to paste the lettering into the artwork, I discovered that its too long, and not quite the right font. But hey, its close enough for this non-rivet-counter. I just had to alter the image by compressing it horizontally a bit.
      That should be good enough to put on an HO Tyco 10 wheeler, if I ever get that far.
      Incidentally, MS paint behaves different in Winders 10 then it did in XP (or 7), and that caused me quite some frustration.
      Once I settle on the actual colours, its a simple matter to go back into MS paint and change them before I have the thing printed out.
    • September 8, 2018 6:45 AM EDT
    • Now I can continue working on my insanity. Thanks guys.
    • September 7, 2018 7:19 PM EDT
    • September 7, 2018 7:12 PM EDT
    • Nope. Me neither. Are you logged in to the https: version of LSC?  If not, that could be our problem.
      EDIT: Now that is weird. First time I tried opening I got Page Not Found. Posted the above then tried again and it opened. SMH
    • September 7, 2018 8:55 AM EDT
    • Most interesting, David....     I'll attach it here...
      C&FW Tender Lettering
    • September 7, 2018 5:28 AM EDT
    • Mick, that's it. Thanks.
      Stan, for some reason I am unable to open any of your links.
    • September 6, 2018 9:56 PM EDT
    • https://www.largescalecentral.com/public/ynforum_attach/11/4b/02/246c8_f224.jpg?c=0a1c&fc=%27C_FW_Rail.jpg
    • September 6, 2018 8:57 AM EDT
    • Double Dupe...  program going wild..
    • Dupe
    • David, sorry 'bout that...  Try this one..  it's a jpg..
    • September 6, 2018 5:32 AM EDT
    • Stan, for some reason I cannot open the attached file.
