Forums » Tools and Tips
List of newest posts
    • February 8, 2020 9:52 AM EST
    • Dan are you at all concerned with the plastic flexing and not giving repeatable results, and will the plastic rollers wear out quickly?
    • February 8, 2020 7:08 AM EST
    • One way to enhance the design that Dave and Dan have proposed is to add another set of plain pinch rollers (rubber coated?)to feed the stock into the grooved forming rollers. am a little concerned on how this will all work in 3d Printed plastic, as the material will wink when a load is applied. sometimes real metal or alum is called for.
      Al P.
    • February 8, 2020 1:25 AM EST
    • Dan.....  Taylor Tin's roller press is of the same basic design.  This is version -3.... Having learned that the first two versions would not work with " annealed Alum. cans",( soda or other beverage).  or annealed Alum flashing from the big box stores, or of alum. duct work. raw and annealed.
      As you can see... your design is much higher refined then my machine.   Yours, with direct gear drive just may well work where mine design failed.
      My top roller is a "Floating" interference design. where the upper limit is restrained from travel, and sets the groove depth.
      EDIT: also shim stock ( by it's very nature) is way to hard, as the kilm i used to anneal would not reach high enough temp to be effective to remove the hardness.   And soft brass would feed, but was prohibitory on the price point.
    • February 7, 2020 8:30 PM EST
    • All good observations, Cliff.  I had intended to simply epoxy that top nut in place, but your suggestion makes more sense but I'll still epoxy it on the underside.  That change has already been made in the model.  The lower nut will work as is since there will be few adjustments once its set the first time but it has been bothering me.  I've thought about epoxying a bearing on the end of the screw and adding a lip to catch the outer race of the bearing and let friction lock it in place.  I'll have to think about that one some more.  The upper four screws are threaded into the plastic and extend a little over 10mm down into the main stand.  I'm not sure there'll be enough upward force to push the screws out of the plastic, but we will see.  I could be wrong, I have been before ...... I think ...... maybe not
      I appreciate all the observations given thus far.  Its always good to have multiple sets of eyes on a project such as this.  If I can get this thing to work, I will gladly share the print files or even the design files for anyone who wants to make one of their own.
    • February 7, 2020 4:30 PM EST
    • Dan Hilyer said:
      Here is the height adjustment incorporated into a stand.  This gives you an adjustment of 4mm down and 10mm up.  Way more than needed.  The initial gap as it sits now would be 0.3mm.
      Great project, Dan! I'm loving how you're 3d printing a fairly complex tool -- which maybe has no equal on the market? How fun!
      Your screw arrangement also caught my eye; you answered John's points, but here's a couple more, if you don't mind.
      If I'm understanding the device properly, you're forcing the upper bearing down toward the lower; and that position must overcome the stiffness of the metal sheet. If so, I expect the upper nut to push upward away from and out of its its pocket. To prevent that, you could put the nut pocket on the underside of the removable upper bar, and perhaps thicken that bar to handle all that upward force.
      Second thought, for your lower nut, since its load surface is on its bottom side, you might want to make room for a washer or something for it to press against. That would spread the load out, and prevent a hex-shape dimple in the plastic (which could fight with the finer adjustments).
      For locking the lower nut in place, if drilling as John suggested is difficult, you could (if you have the vertical height) plan for a double jam nut, which can be far more secure than nylocks or Loctite. Alternatively, you could save space and turn your socket head screw upside-down, and use a jam nut against a threaded knob on the top side. That way you'd see if something was loose, and be sure all was firm down below.
      Finally, since you're screwing into plastic (or maybe you're using metal inserts?), and since those upper for screws will see your upward force, I'd make your upper bar as wide as the main mount, and center the screws. That way, if you later need to install inserts (or larger screws, if those holes give way), you'll have plenty of space to work with.
      Just thoughts, take them for what they might be worth... My main point remains the same though, that this is such a cool project, and I'm really looking forward to your cranking out some sheets!
    • February 7, 2020 2:23 PM EST
    • That's more or less what I am attempting to do, Bob, just with 3D printing.  Based on Dave's input, I think I am going to try the male-female style rollers first, though.
    • February 7, 2020 8:25 AM EST
    • I see...
      I'd suggest drilling and pinning the nut to the shaft, just because of the stresses.
    • February 7, 2020 1:01 AM EST
    • John Caughey said:
      You may run into tearing on the standing seam if the metal can't gather material from the sides for the height. Might require 2 passes one to form the seam and the second to form the bends to flat determining the height of said seam.
      Bearing drawing, No threads on the lower half of the adjusting screw, It needs a ring to fit in a groove on the shoe for up and down motion controlled by upper threads. No?
      John, it appears that way but in reality that lower nut is captured but can rotate and I will epoxy the nut onto the adjustment screw so the adjustment screw will travel with the rollers.  I could simply print a ring as you say with threads and epoxy that to the screw.  End the end either way will work.
    • February 7, 2020 12:43 AM EST
    • You may run into tearing on the standing seam if the metal can't gather material from the sides for the height. Might require 2 passes one to form the seam and the second to form the bends to flat determining the height of said seam.
    • February 6, 2020 11:22 PM EST
    • Thanks for the insight, Dave.  I prefer the grooved male - female rollers to the ones I presented above.  Much less printing.  I was just worried about there being enough friction to pull the material through.
      Per your recommendation, here is the first pass at a vertical adjustment mechanism.  It still needs to be incorporated into the model but that's the easy part ..... I hope.
      Yeah, I know, I should be working on my MIK project, but all I like other than the painting is installing the roof trusses and mounting to the deck and I'm working on that.  all the printing is done ..... FINALLY.
    • February 6, 2020 9:43 PM EST
    • The Taylor Tim factory uses the duel grooved male and female roller system like your last pic.   The harder the metal,  the more difficult it is to get the "grab" on the rollers.  Softer, "annealed" metal will "stretch" as it passes thru the rollers.
      Harder, metal will be stretched to the cracking or tearing point.  In the real manufacturing world, corrugations are rolled one grove at a time, allowing the metal to form without a great deal of stress or stretching, more of a fold, then a stretch. The metal passes thru a series of forming dies from the start to finish.
      Dave
    • February 6, 2020 7:24 PM EST
    • Dave Taylor said:
      Dan...... Not to burst your bubble...... But.... I don't see any means to adjust the depth interface between the two rollers...   Very important to regulate the depth of the crimp, and the clearances between the rollers for any changes in material thickness, and annealed state...
      Details, details ....... thanks for pointing that out, Dave. Believe it or not, I had thought about that early on in the design process but chose to fix the distance based on the 0.002 steel shimstock I am using.  Probably should (will) make that change once I get the rollers printed.  Question, regardless of the method used to adjust the height, there is always the issue of keeping the adjustment roller level because I am assuming, without giving it much thought, that the two ends of one roller will have to adjust independently. So how do you keep them level?  Count turns on an adjustment screw?  Pre set adjustment heights?  Any suggestion?
      EDIT: To ask one more question.
      Dave, I considered trying a roller orientation as shown below, but I don't think there will be enough friction to pull the stock through and its not stiff enough to push.  Any thoughts?
    • February 6, 2020 5:26 PM EST
    • Dan...... Not to burst your bubble...... But.... I don't see any means to adjust the depth interface between the two rollers...   Very important to regulate the depth of the crimp, and the clearances between the rollers for any changes in material thickness, and annealed state...
    • February 6, 2020 4:14 PM EST
    • Dan;
      Sorry you experienced that mishap.  The freeform mass of plastic filament on your 3D printer does remind me of excelsior. (Remember that stuff?  As a child, I actually had one or two plush toys that were stuffed with excelsior.  They were not very cuddly.)  Anyway, what I am trying to say is that you could perhaps salvage it as packing material.  Expensive, I know, but still better than just throwing it away.
      Best of luck for your next try, David Meashey
    • February 6, 2020 3:48 PM EST
    • Dan
      This is quite interesting, curious to see this finished, Please keep us in the loop
      Dennis
    • February 6, 2020 9:09 AM EST
    • 3D printing, it's not just for making parts any more, it also makes tools.
      Ah yes, kitten-proofing the hobby and work areas ... fortunately both my guys are heading toward senior cat ages and have a better sense of discretion than in their kitten years.
    • February 6, 2020 12:32 AM EST
      Are the tops of your ribs rounded?
      Biggest complaint about the crimper is it makes folds instead of reverse curves.
      Run the mess through the crimper and call it roofing.
      Yes, John, the profile is reverse curves. The good thing about making this is I control the profile. If this all works like I expect it to, I will make several profile rollers like standing seam roofing.
    • February 6, 2020 12:17 AM EST
    • Are the tops of your ribs rounded?
    • February 5, 2020 11:30 PM EST
    • I've been making corrugated tin with the paper crimper you can get at most craft stores and it does a good job, but its not quite to scale and you get what you get.  So, I decided to attempt to make one that was more to my liking.  Over the last several weeks while waiting on parts for my MIK project to print, I've been refining the design and am finally where I think I am ready to create at least the first prototype.  I expect there will be refinements, but I got to start somewhere.  Here is the model as of now.
      Last night I started printing the two rollers, an 18 hour print.  I came home from work today to this ( I posted it earlier in my MIK build log):
      You can see a partial roller in the left rear of the printer.  The other roller is behind all the wasted filament.  For some reason, at some point, the rollers moved.  I think it can be attributed to a curious kitten, but not sure.  Anyway, I have restarted the print but only a single roller at a time.  All toll, its about a 35-40 hour printing project.
      All comments, suggestions, criticisms welcome.
